Any ideas as to this leak?
How do i fix this problem guys?
29705.attach
Looks like a new EGR valve is needed
Thats what I was thinking. I took it off and had a look - it was filthy inside, so a liberal amount of carb cleaner and elbow grease has it shiny smooth inside. Although the manifold is also dirty with all the oily carbon.
Ill see how long it is before it leaks again.
What faults would a broken EGR valve produce??
its not broken , its just leaking oil , so no fault codes will be present
Well i suppose I can put up with a little leak...............:o
