Coolant level warning mystery
I was hoping someone could give some help in tracing what's causing my coolant level warning on the dashboard.
It's a 2008 2.0 diesel. The warning is the three beeps and the red light flashing on the dashboard.
(1) The coolant level is correct;
(2) I've replaced the expansion bottle which came with a new sensor which made no difference to the problem;
(3) the contacts to the sensor in the expansion bottle look very clean;
(4) the engine is not running hot, the warning usually comes on within a minute of starting from cold;
(5) the temperature gauge is working as normal.
Sometimes the warning doesn't happen, usually if I've driven the car, left it for an hour or so then started again. This could be random as I've only had the problem for a few weeks.
Assuming the level sensor is working as I've replaced it, is there another sensor that can cause the warning, I'm thinking one that says the engine is too hot, that could be faulty? Or is this the same as the one that operates the water temperature gauge on the dashboard?
Is there anything else that I can check?
Thank you.
Recently Browsing 1
