Enabling curve lights-LED daylights error-Zenec NC2010 facial plate
Hi guys,
regards from Serbia.
I just bought Skoda Octavia 2 FL,
and I need a little help.
1. I bought car with original HID package, but curve lights are disabled for our market, they told me in Skoda Serbia that this can be enabled, but they don't know how to do it. They only know to enable some showroom function in VAS, and curve lighting is working under 20 km/h. If you pass this speed curve lights are automatically disabled. How to permanently unlock this function?
2. As I have daylights in Fog lights as separate bulbs, I decided to change BA15 12V 21W bulb with LED bulbs (see picture). Board computer shows me error in left and right daylight bulbs. Idea is to parallel connect resistor to simulate bulb resistance, but I don't know which resistor to put (I need ?Om an ?W). I measure bulb resistance and it is 1 Om.
3. I bought Zenec NC2010 for my car, but I need new facial plate in original aluminum design (Shape is like for Amundsen or VW Golf V-VI, Passat). There is some on
Octavia II 09- Facelift w/NAVI- dashboard plate BRUSHED ALUMINIUM : Skoda Tuning = superskoda.com
but it is brushed aluminium. Can someone find me original spare part number so I can order it?
Regards, Sasa.
Edited by vranic
corner lighting by eu law must disable of 20kmh, its designed use is for low speed guidence whilst exiting a junction or parking. Therefore it is not possible to have this function all the time, all you can do is turn this on/off. the 20kmh limit is software programmed and not an adjustable setting.
It should be possible to get a radio facia, what you need is the dealer to get one for a columbus unit, as this is available in the facelift car it should be possible.
Corner lighs are working as factory default, and thats OK, but curve lighting (HID Xenon moving left-right) is disabled, I want to unlock this function.
About facial plate, I found Skoda O2 FL with amundsen navigation, shape is the same but there is no part number on facial plate, so they can't order it.
About LED daylights, I still have a problem on my MFD, and I don't know which resitors to buy to close the circuit.
Regards, Sasa.
