Felicia oil light delay
Hi to all from Turkey :)
I have noticed that when starting from stone cold (and also from warm when standing for minimum of approx. an hour) the oil pressure warning light takes a good 5 seconds to estinguish
i'm using 20w 50 castrol GTX, car is in very good condition and well maintaned but i'm really worrying about oil pump gears.. :confused:
odometer shows ~ 153.000km and never opened engine for a repair instead of valve clearence adjustments for 11 years ..
any suggestions welcomed :)
hoops forgot to say its 1998 facelift felicia with jikov carburated 1.3 engine (135L 43kw)
153_000km on the original timing chain? You don't find the engine rather noisy? (no tensioner)
I'd try a lighter cold grade oil (say 15W50), and a different brand of oil filter.
no no i've already changed the timing chain and sprockets sorry for misunderstanding.
i mean it never overheated , never opened the cylinder head for a gasket or lineer change. engine is still original from factory just keep working fine with regular maintenace.
thanks for your suggestion :)
Edited by AhmetH
