Vista and Photoshop cs4 problems
Hi guys,
I recently tried installing a copy of cs4, my best mate gave it me as it installed ok on his xp and vista comp,
i got it copied it across and started the install and it failed, i think its because i didnt run in adminstrator mode, doh
now when i uninstall and reinstall it keeps on failing, ive tried cs3 but this fails also
its a brand new comp nothing else on it other than acrobat reader,
is there any way i can uninstall the bits of cs4 and 3 that are hidden in the depths so i can install correctly without a format
thanks in advance
Rob
Edited by fatty5000
Iegal reasons lol
You'll probably have to go into the Registry and search for the Photoshop Installer keys.
Not for the faint hearted I might add.
Also, before you do any tinkering of any sort make sure you've got a backup of your system and important settings.
You might be able to start 'anew' by using a previous system restore point thereby not needing to tinker.
Edited by anonymouse
fergot
would a system restore to when i got the comp work,
or maybe a spybot program to remove registry files
Yeah, but everything goes with it so do some sort of back up of your doc's etc.
