diesel injectors
:confused:My estate's done about 78k ...when is it recommended to test/service them?are they tricky to remove/any thing to watch out for? any info gratefully received!:)
only take them out if you suspect they are dodgey, otherwise leave them well alone
As above, if they are working, leave them alone. You may want to check the bleed off pipes as these can leak.
good advice....thanks for your replies:orb_cool:
