what else should i change/upgrade
well im just about to upgrade my vrs to KWV1 Coilovers & Jabba rear ARB and was woundering what else should i change/upgrade whilse i was doing this,any help advice would be much appreciated,part numbers ect.thanks:)
you could get the cupra front bushes? they don't cost much but a bugger to fit.
as said aboce, espcially if your fitting coilovers, because your standard bushes will just fall to bits.
while your at it get powerflex front wishbone bushes and powerflex arb bushes, this way the front will be completely new and you won't have to worry about it!
Allan
:thumbup:thanks,what size bushes for the vrs front arb? theres 3 sizes...
is this what i need ;
Front Wishbone Front Bush PFF85-601 x2 (+£24.67)
Front Wishbone Rear Bush Insert PFF85-602 x2 (+£32.92)
Rear Beam Mounting Bush PFR85-415 x2 (+£39.52)
Front Anti Roll Bar Bush 19mm PFF85-603-19 x2 (+£21.37) or 16mm or 18mm? i have a standed 2006 vrs so what size is the front arb
you need the front wishbone front bush, don't get rear bush insert (just get cupra ones). the insert is only for if your bushes are fine they just go over tthem. plus cupra bushes are ALOT cheaper
you wont need the rear beam bush.
and I'm pretty sure the rear beam size is 19mm
Allan
Brakes?
If your doing them anyway, then it would save time to do them now?
And if your changing your brakes, then you want a couple of letres of dot5.1 fluid.
Dave
