Airbag warning lamp
Hi Guys, hopefully some one can advise me.....
Had the annoying relay clicking in the centre of the dash so have replaced the indicator stalk,
cured the annoying clicking, but now i have got the airbag warning lamp on as i may have switched the ignition on while the steering wheel/airbag was removed disconected!! Doh:(
Iam considering getting vag-com as the car is getting on a bit now but after reading a few of the faqs on ross tech it seems that i may need th pro version to deal with this issue??
Is this a simple reset as nothing has fired or is it a major pita?
Advice appreciated
Thanks JGT :)
It's easy to do, but you need a licensed version of VCDS as basic settings/adaptions are not available in the shareware version.
[select]
[15 - Airbags]
[security Access - 16]
Enter 30475, to enable the basic setting.
[Do it!]
[Adaptation - 10]
Channel 000
[Read]
[save]
[Done, Go Back]
[Close Controller, Go Back - 06]
Battery off for a few hours, not 100% it will cure it but it's free.
Cheers rwbaldwin, thats good to know:thumbup:
Supurbia thanks for a cheap suggestion, however i havent got my radio code dont think i like the idea of not having no choonz.
Allthou it may have to do, the mrs wasnt to happy with me wanting to spend £250. squid on some software:eek:
Thanks JGT
