Starter motor
I fitted a new starter motor to my Felicia. Initially I was confused about where to put the +ve lead from the battery. When I connected it to the bottom terminal, on the solenoid, and touched the +ve battery lead onto the battery a whirring noise occurred so I reversed the leads and the starter worked. Unfortunately the alternator light, ABS light and brake fluid light remain illuminated when the engine is running. Does anyone know what I have damaged?
Confused Guernsey.
Felicia 1.3 MPI 1999
Edited by solves
Rewiring the conections on the starter motor solved the problem!!! May be of use to someone?
