error codes 16891 and 17544
Hi Guys
Im selling my octavia (need a van going to miss it massively best car ive ever owned by a mile) and really want it to be right for the next owner so im looking to fix a couple of issues the car has at the minute
Ive recently cleaned the throttle body
Had error codes before for the front 02 sensor so replaced it and now im getting the following error codes
16891 Idle Control System Higher than Expected
17544 Long Term Fuel Trim Add.Fuel,Bank1 System too Lean
Any ideas on how i can fix these?
Cheers Matt
Try this web site as well :- Main Page - Ross-Tech Wiki then look under fault codes
anyway I did a search and found this :-
16891/P0507/001287 - Idle Control System RPM: Higher than Expected.
Possible Symptoms
  • Malfunction Indicator Lamp (MIL) active
Possible Causes
  • Throttle Valve Control Module (J338) dirty/faulty
  • Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
Possible Solutions
  • Check Throttle Valve Control Module (J338)
  • Check Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
17544/P1136/004406 - Fuel Trim: Bank 1 (Add): System too Lean
Possible Solutions
  • Check Mass Air Flow (MAF) Sensor
  • Check Fuel Pressure Regulator
  • Check Fuel Pump
  • Check Intake/Exhaust System for Leaks
  • Check Secondary Air Injection for Leaks
  • Check Vacuum Lines for Leaks
Peter
Thank you sir i was just outside listening to it i think i have a slight air leak. That might explain the second one.
Ill get a photo of the offending pipe hopefully someone can tell me which pipe it is etc
Cheers mate
Im going to have a really good look at this on friday and see if i can identify the culprit.
Cheers Matt
Yeah the second code is a common one for leaking breather hoses.
Either the Y-piece off the rocker cover, or the S-hose from the T-piece to inlet manifold. That one's under the manifold, to the right hand side. You can get your hand on it to feel for leaks easily enough.
With the 1st code, did you disconnect the TB when you cleaned it? And did you perform a reset if you did disconnect it? I'd clear that code and see if it goes away, as the TB should self adjust after a few miles.
Cheers Buddy
These are all things on my list of things to do tommorow!
i didnt disconnect it. I only have a handheld scanner not vagcom so couldnt reset it if i disconnected it.
i know this is cheeky but dont suppose you could post a pic of the engine bay and an arrow to explain which pipe you mean?
Cheers Matt
