abs & asr lights on help me plsss!!!
hi everyone i`ve got a 2003 ,1.4 16v fabia comfort and the abs and asr lights on anything to solve them when i`ve scanned dtc-01 65535 error code appears what can be the problem please? thanks
a 65535 fault code often means the module has failed. It's not usually something outside the control module. These is a fairly common ABS module failure.
65535 - Ross-Tech Wiki
thanks for help so do you mean i need to change the module or sensors coz i`ve red in forum can be battery, sparks, wiring, etc. do you know anything about the flicker lights maybe i just need to change battery i dont know but whenever i run the engine when i see those 2 lights on dash i get crazy
Did you read the troubleshooting suggestions in the Ross-Tech wiki link I provided? does it not tell you to check wiring and/or replace the module?
sorry i`ve just red it but i dont know where is controller stated do you know any site that i can download service manual it doesnt show where is controller but service manual will how it i think thanks
