coming and leaving home function
hi all
i have enabled coming home and leaving home function in my car, i dont have light sensing " auto or tunnel "
so how it will work , do i have to leave the light switch always on or what
Did you order it with Auto lighting?
If you did then you put the switch to AUTO, it should then work.
no i didnt order it with auto light
i enabled the ch\lh with vag-com
it appears in maxidot now , but not working !!!!
You have to leave the Light Switch in the on position.
You will find now that when you open the door with the light switch in the on position you no longer get the Warning beep.
In Maxidot you can then alter the amount of time the lights stay on for when you Lock/Unlock the car.
I did the same thing with my car
HTH
Carl:thumbup:
