PD140 Front Brake Size
Does anyone know the size of the standard front discs on the Octy2 PD140 hatch - to save me taking the wheel of and measuring them.
280mm sound right? i jus looked on euro car parts, stick ur reg in and look at some sets.
matt
288 I believe
If they are either 280 or 288 is there any real benifit to be got from fitting 312mm brakes
well i guess it depends how much u feel ur brakes are being used now? I`v jus put 312mm on my fabia, but that was because i was getting some lovely brake fade. lol
Yes fade is what I am looking to overcome
in that case i suppose theres two route much like the fabia. Either go for 312s, which would need to be off a mk5 golf for your octy i think, or try upgraded discs and pads.
Standard the PD140's come with ATE callpers over 288mm vented discs (25mm thick new).
I created a thread on the forum about parts needed to convert them to the 312mm discs as per the VRS and that provides a lot more brake prediuctability to the car.
A search on 312mm in the octavia II section should find it.
EDIT: Found it for you:
http://briskoda.net/octavia-ii/312mm-brake-upgrade/106188/
