Can bus
hello
i need some help,i would like to know if the fabia have can bus:confused:
thanks
hello
thanks
The Fabia is an older k-line based car, but it does have some CAN networking, but it's not fully implemented in the car. If VCDS (VAG-COM) IE Diagnostics is what you want this for then thats better for you because you can get a cheap aftermarket cable that will work
so i can make my navi cooperate with my maxidot gluster only with the 3lb wires,right?
Not 100% Sure, I have a Fabia II which is mostly the same as the MK1, and I couldnt get my mfd2 to display on the maxidot, and the RNS 510 doesent work because the speed signals and abs sensors wont communicate due to lack of canbus
i guess i have to try it and see if works or not:cool:
What Navi Unit are you using?
the original skoda dx,i bought it used from ebay
I think that will work okay, they are used in older vag-group cars. As for maxidot functionality I dont know what it offers
indicate larger all the informations from the trip computer and also display infos from the radio and navi
