Fitting a pasenger side door cable
Hi guys
Can anyone help me? Im trying to fit a door cable to my octi mk1 with no success!! i have hooked it around the lock and the loop on the handle but when i screw the door panel back on the cable is still very loose and has no effect on opening the door!
Is there a way of tightening this up?
Please help if you can as i cant find the answer anywhere..
Glen
If you look near the door handle there is a small 'top hat' shaped plastic part that has to clip inside near the door handle.
I'm guessing this is your problem.
Thanks Jaymd i'll check it out..
