Front Seatbelts Problem tensioner replacement question
My octy is now 11 years old and the front seat belts will not go back to their resting position and if i forget they get trapped in the doors, is it easy to replace the spring tensioners for the 2 front belts and more so is it expensive or better left to a garage to do.
Thought i could put up with it but they are doing my head in now.
Is there any tension left at all on the belt spring?
I thought mine was gone, but after a bit of patience, and a ****load of cheap furniture polish on the belt
it started working again fine
seems a few years worth of dust on the belt slows it down thru the mechanism, but the polish helps it all slide thru again
Steve
