where can I get a vrs grill?
Hi, I had a wee shunt in my non fl Vrs and now I need a new front grill, it's just the black plastic bit. I have searched on ebay but there is nothing and a quick search online was unsuccessful. Does anyone know where I could get this part and how easy it is to replace it? Thanks in advance.
I would try your local dealer. Fitting is fairly easy.
Thanks, I have found one on SuperSkoda website but i will contact my dealer to find out if they are any cheaper.
Main radiator grille part number is (1Z0 853 668 B41) it abaut £25+vat from dealer
It's a very simple job to remove the grille-
1 Open bonnet
2 Remove torx screw from rear of skoda badge (under bonnet)
3 Release securing clips (i used a socket to squeeze the clips)
4 Remove grille - be careful not to break lower lugs in bottom of bonnet
5 Next you need to remove the chrome surround from old grille
6 Remove the securing clips from grille - you'll need these to refit grille
7 CAREFULLY prize the chrome clips away from backing
8 Once clips are free the only thing that holds the chrome to grille are three long runs of trim tape
9 Remove any traces of tape
10 Refit in reverse order
rob:thumbup:
