Skoda Octavia VRS 2002 drivers door not opening off key fob
Hi
My drivers door is not opening off the key fob and the alarm light isn,t comin on either, all other door open with key fob just not drivers. Works fine with the key and doesn,t seem tight or stiff. Indicators flash still with key fob
HELP :D
Many Thanks
It will be cuted wire - red/yellow between door and chassis...
Hi thanks for that, what do you mean by cuted though
It means the wire mentioned will have been cut between the door and the body
I thought it did but I thought I,d ask lol.
Can either of u tell me how to change discs and pads, do I just take the slider off or does the caliper have to come off as well.
And what tool do I need to wind the pistons back on the rear, is it the same as for the Mark 1, the lazer1314 tool? Is left or right thread needed?
And to use the tool the caliper would have to be off or the disc removed to get the tool in is this correct?
Thanks for your help :thumbup:
Its the same tool just remove the caliper and screw it back home, then clean the pins and put a film of grease on them and the pad guides
Thanks Skippy
Any advice on a frount spring? 1 of those has broken also.
The car has been stood for 18 month and everything has broken lol
And I,ve never done rear discs before, someone said the handbreak is in the middle? can you give any advice on this please, are they easy to do?
many thanks again for your help :thumbup:
as far as the "cuted" wire is concerned; you'll probably find that the pins have corroded on the multi plug inside the door, as mine did.
Inside the door panel, attached to the bottom of the window winder mechanism is a black box with a 21 pin plug on it.
Usually, water gets into this plug and just sits there, corroding the bottom few pins.
Does your drivers door mirror still work? (because mine stopped about the same time as the door lock...)
Good luck, it's a b*gger to fix...
No mirror is still workin, did you have to clean the multi plug or replace it?
You say its a bugger to fix?
What was the problem, getting to it? Replacing it?
Thanks for your info m8
And it says you have a bug Jonny?
I have a 1966 Splitty
Had her for 13 years+.
Just done IRS, not finnished yet but close, can,t wait to try her out
I'll move this too the Mk1 forum
HTH
