Leaking Sunroof
Hi,
water started dripping from sun visor above driver seat this morning. When I pulled visor down the roof above it was wet. After some investigation I also notice water was dripping down the side of the drivers footwell and making the carpet wet. I opened the sunroof and notice a pool of water just inside.
Is this the seal gone, or could it be something else. If it is the seal, how hard are they to replace?
Cheers,
Martin
There's a drain pipe iirc, common issue, clean the channels and look for the pipe, if you do a search there is a thread about it.
