ARB Bush holder bolts!
My bushes are creaking again, and I always have a hell of a job getting the bolts back in after lubing them. Someone suggested using longer bolts with the same thread to pull the bracket into place then swapping them. Why didn't I think of that? :doh: So my question is - what length and thread are the stock bolts? Anyone know so I don't have to pull one out to see before starting the job properly?
I recently replaced mine with Superpro (assuming you mean the front arb), and also tried a longer bolt solution, didnt work as it bottomed out on a feature on the subframe before securing the clamp.I ended up using a pair of long handled adjustable pliers to hold the bush clamp closed and then quickly fitted the original bolt before my strength went. The bolt in question is:- N 101 016 03 M8 x 18mm Long.
Edited by Silver Bullet
Cheers :)
