regrets is it time to say bye to skoda?
well thinking i not so keen on my skoda fabi estate tdi .
first of wheel bearing had to be changed both sides car has done 184000 miles but wheel bearing`s where replaced at 178000 , then abs sensor packed in and had to have new wheel bearing !! , brakes which are new (disk`s and pads ) alround about 6000 miles wont stop squeeling and hand brake works when it feel`s like it .. had the comon wiper fuse prob when the snow fell , and drivers window refuses to work at moment :doh: .. but to finaly put the boot in engine cut out half way across t juction car would not start just spun ,so to move it i put it in second gear and turn`d it on started it did start and get me home and sat ticking over nice when i turn`d it of wouldnt start again , well mot up end of month so guess i maybe getting somthing else very soon
To be fair it has done a lot of mileage! If I had a car of that mileage I would be pleased it had got that far lol! :thumbup:
My brakes squeel a bit on my Octavia after the brakes were changed. I took it back to the garage, still no better. I took it to another garage, and guess what, two weeks later same problem. My solution is to turn the stereo up a bit louder now! :giggle: Luckily it only does it at low speeds.
To be fair 184000 is quite high mileage for any car (even a VAG)
It is easy to be disheartened when things go wrong, but fortunatly most furby problems are common, easy to fix & there is a lot of info on them around here.
The brakes squeeking can be fixed with some anti squeeking compound that most garages/service centres will have (so I have been told).
At the end of the day its about how much the cars is costing you to run vs the cost of a new car! :p
if youve been happy with it so far whats to stop you getting another skoda, surley something thats done that many mile cant be half bad at all! :)
The squeaking brake problem is to do with the lack of copper grease on the pads - or so i've been told... mine did squeak but after the grease was applied no more squeak! :)
well garage looking at it , so far fuel filter , been changed and engine oil lol.
If you can get it through an MOT and then want to get rid of it, drop me a PM with a price ;)
ok dont think theres a prob getting mot on it most things are new ie front rear disks pads, new front subframe arm ,wheel bearings ,and battery.. :thumbup:
well turns out that the temp sensor is at fault , thinks we in the summer (was -4) today .. should of guess`d that had to replace one on my seat 130tdi this summer lol.... :doh:
well picked up car this afternoon and started of great run really well the outof the blue it stop`d again :'( so phone call to garage and its back in :no: so not loving skoda at moment think the dark side is calling me (jananese) lol.. B)
got car back from Skoda garage now , turns out it was the ECU unit at fault £1200 repair !!! however mecanic has put a switch on dash to bypass unit so car will start only £248 !!! ..never had such an expensive car to run :dull:
Question for the techies - would it be possible to get a second-hand ECU (eg. from a scrapped car) that would be likely to work?
yes it would i believe, buit would have be retuned to your car i believe,
my ecu went on my old rover 25, i got a 2nd hand one from scrap yard but had to be programmed by dealer, it cost be £75 for the programming and £30 from the scrap yard for the ECU considerably cheaper than the £1100 quoted by rover
Has the car ever been chipped?
