Help Needed.
Ok on the HPFP on a Octavia vRS TFSi (pre-Facelift) their is a brass valve called a Schraeder valve i think
Apparently this is not a seperate part from VAG and they want £164+ VAT for a new pump which i am not paying just for the valve.
Does anyone know where i could get one (apart from a scrapyard as i have tried but no luck)
This pic shows the bit i need
Thanks in advance
Carl :thumbup:
I may have an idea, but I don't know what an HPFP is, or what sore of pressure it runs at, so I'm reluctant to expand without further info.
It's the fuel pump
Carl :thumbup:
A Schrader valve is what is used on your tyre, but the one in the picture looks to be bigger. If a regular tyre pressure guage or pump fits, try your local fast-fit for a metal valve probably suited to industral or agri use. Obviously depends on pressures though...
About 140bar
It's the same sort of valve as there is a nipple under the dust cap you press in to release fuel pressure before removing the valve
Carl :thumbup:
Edited by vRSCarl
Try Rema Tip-Top in Leeds (part of Stahlgruber group) who supply fast-fits, and ask about spec on pressure and fuel resistance.
I agree with jeeves..if this is the part you need , Schrader valves are the same on a push bike, as on a c130 hercules transport aircraft !!..you can get one here
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_182195_langId_-1_categoryId_229402
