Facelift Xenons
Just wondered how you get the xenons washer jet function to work , had a look through the hand book but cant seem to find it :doh:
In my preface life car if the lights are powered on and you pull the left hand stock for the windscreen wash the headlight cleaning jets also activate, think the sytems then only washes the headlights every third pull of the stalk after the intial clean but the count is reset every time the ignition is turned off. Imagine its the same for the facelift cars...
Edited by AMB_1
First pull of the wiper stalk for washers when the headlights are on. Then its every 5th pull of the stalk until the lights and/or the ignition is turned off. You can bypass the headlight washers by giving the stalk a quick pull and then pull it again to just wash the winsdcreen.
