Mirror Glazes
Hi all.
Which one do I apply first the G220. I have bought bothe Meguires #80 and 83# Mirror glaze products. Do I apply the Meguires speed glaze #80 first or the dual action cleaner/polish #83? Not sure. The #83 is more course than the #80...... so im guessing #83 then the #80?
Sounds confusing sorry.
Anyone else know?
Cheers,
Gaz
always start with the least abrasive no. 80 if it doesnt achieve the cut you want ie removed all swirls , move to the no. 83. if you want to refine the finish after 83 use the 80 again.
hope this helps
Done a newbie course the other day and he said, if one combination doesn't work move to the next combination
Fine Polish & ………Finishing Pad (Softest)
Fine Polish & ……….Polishing Pad (Medium)
Fine Polish & ……….Cutting Pad (Hardest)
Medium Polish & ………Finishing Pad
Medium Polish &……….Polishing Pad
Medium Polish &……….Cutting Pad
Hard Polish & ………Finishing Pad
Hard Polish &……….Polishing Pad
Hard Polish &……….Cutting Pad
Then work backwards to finish off.....
Great. Cheers for that. I knew there must have been some order.
Cheers,
Gaz
