Quick DV fitting question
HI,
Just got a used Forge 007 DV. Am i right in thinking that on my standard Vrs i need a green spring for it? If so does anyone want/need/fancy a swap with a blue one!!!
Also i know i'll need 2 new ring clip type things to fit, but do you just use a cable tie on the small pipe from the top? Any other useful fitting tips would be gratefully received.
Thanks in advance
a cable tie on the small vac line is usually OK and you will need either a green or yellow spring.
Edit: Green for standard and some remaps, yellow for remap
Edited by karlbar2k
Many thanks for that, best get a green spring ordered.
If anyone has a green spring for one that they dont need please let me know, especially if you want to swap it for a blue one! :)
If i knew what pressure the turbo was putting out as standard
Unless you've got a remap it should be putting out around 10psi, or 0.7 bar
What's the blue spring for? Is it for stooopid high psi?
