Got a Big problem with the Blue Bullet
Got these fault code below.
According to RossTech wiki for the first one it says
Possible Causes
Throttle Valve Control Module (J338) dirty/faulty
Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
Possible Solutions
Check Throttle Valve Control Module (J338)
Check Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
1 Fault Found:
001287 - Idle Control System RPM: Higher than Expected.
P0507 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 88289 km
Time Indication: 0
Date: 2000.00.00
Time: 00:12:48
Freeze Frame:
RPM: 1174 /min
Load: 14.1 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 44.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.224 V
Readiness: 0110 0100
Then a bit later got this fault
1 Fault Found:
008825 - Leak in Air Intake System
P2279 - 002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 88294 km
Time Indication: 0
Date: 2000.00.00
Time: 00:30:47
Freeze Frame:
RPM: 846 /min
Load: 14.1 %
Speed: 0.0 km/h
Temperature: 91.0°C
Temperature: 41.0°C
Voltage: 14.097 V
Nothing on RossTech wiki for that fault.
Basically the car is Idling very high (circa 1250-1500rpm)
The only thing i have done is put a new battery in it that i got from the VW dealer nearby so its the correct battery as was done by part no.
Couple of questions
Where are the
And where it says leak in the Air Intake system is that literally from the EVOMS to the Turbo or is it also including the route taken by the gases as they come out of the turbo to the Throttle body? (i.e turbo outlet, intercooler, intercooler piping and throttle body hose)
Help would be appreciated as car is due MOT in a few weeks and will no doubt fail if thats not fixed
Carl
Cancel my last
Turns out it was a small problem
I had a hole in this pipe. Just replaced it and all is well
Carl
Had a look on ETOS, the throttle valve adapter is bolted to the underside of the intake manifold. I guess the control module is bolted to the side of it.
Edited by GSPK
