Replacing side/parking light bulb
Hi everyone,
one sidelight on my Superb decided to stop working.
I've got the new bulb. How do I remove the faulty one? I've got access to the bulb and can reach it and can turn it 360 degrees but don't know how to take it out. Do I have to use jus brute force to pull it or am I missing somethin?
Thanks you
Hi everyone,
Thanks you
Easy way is to get a small flat blade screwdriver and gently lever it out, they don't turn it's just in and out, if you pull the earth wire off above it it helps with access also.
Thank you.
I'll try that today.
