Fog lights installation
Hi, does anyone know if it is possible to install fog lights in a car that did come without them?
If possible is it necessary to buy also any other component than the lights?
- extra cables?
- Interior switches?
- Any mod necessary with the VAG-COM?
The car is an Octy II 1.6 MPI, this is the photo:
- extra cables?
Hi
It is possible, if you want to do it all OEM then you will need the fog lights, wiring harness and a high end Central Electronics Control Module
http://www.geogob.net/vw/fog_install_ver1_rev1.pdf
This is for the VW Golf Mk5 but the Octavia is based on the golf and uses a lot of the same parts
The electrical equipment and modules differ from G5 to O2 FL, O2FL resembles Superb 2. Here are the installation of the Superb 2.
You will need switch lights, wires, and OEM projectors. No need to change 09 module, only to recode with fog light.
Extrawires that you need to fit:
From T10b pin 5 light switch to T52a pin 21 CECM ( T10b/5 to T52a/21)
from T52c/25 to pin 1 L23 - Fog light bulb, right
from T52a/25 to pin 1 L22 - Fog light bulb, left
from both pin 2 fog r/l light to earth.
In Attachment you have pinout for j519 CECM.
Contact assignment of multi-pin connector at onboard control unit - J519
A - 52-pin connector, (black) T52a:
1 T52a/1 - Input - terminal 30
2 T52a/2 -
3 T52a/3 -
4 T52a/4 -
5 T52a/5 - Output for main beam bulb, left
6 T52a/6 - Output for rear fog light bulb, right
7 T52a/7 -
8 T52a/8 -
9 T52a/9 - Output for turn signal bulb, rear right
10 T52a/10 - Output for turn signal bulb, front left
11 T52a/11 - Output for dipped beam bulb, left
- Output for gas discharge lamp, left
12 T52a/12 - Input of rear lid lock unit - terminal 31
13 T52a/13 - Input of rear lid handle release button and of two-piece rear lid button
14 T52a/14 - Input of bonnet contact switch
15 T52a/15 -
16 T52a/16 - Input of reversing light switch (not valid for vehicles with automatic gearbox)
17 T52a/17 - Input of rear fog light switch
18 T52a/18 - Input of light switch - terminal TFL
19 T52a/19 - Input of light switch - terminal 58
20 T52a/20 - Input of light switch - terminal AFL
21 T52a/21 - Input of fog light switch
22 T52a/22 - Input of light switch - terminal 56
23 T52a/23 - Input - terminal 31
24 T52a/24 - Input - terminal 30
25 T52a/25 - Output for fog light bulb, left
26 T52a/26 - Output for brake and tail light bulb, right
27 T52a/27 - Output for tail light bulb, left
28 T52a/28 - Output for reversing light bulb, left
29 T52a/29 - Input of rear lid lock unit - terminal 31
30 T52a/30 - Input of power latching system limit switch, luggage compartment locked
31 T52a/31 -
32 T52a/32 -
33 T52a/33 - Input of rear lid closed switch
34 T52a/34 -
35 T52a/35 -
36 T52a/36 - Input of deactivation button of interior monitoring and vehicle inclination
37 T52a/37 -
38 T52a/38 - Input of rear lid connection motor left
39 T52a/39 -
40 T52a/40 - Input of rear lid connection motor right
41 T52a/41 - Input of power latching system limit switch, luggage compartment unlocked
42 T52a/42 - Input - terminal 31 - for central locking
43 T52a/43 - Output for rear window wiper motor and windscreen and rear window washer pump
44 T52a/44 - Output for side light bulb, right
45 T52a/45 - Output for bulb for high level brake light
46 T52a/46 - Output for rear lid power latching motor
47 T52a/47 -
48 T52a/48 - Output for tank filler flap locking motor and for rear lid connection motor left
49 T52a/49 - Output for rear lid connection motor right
50 T52a/50 -
51 T52a/51 -
52 T52a/52 -
B - 52-pin connector, (white) T52b:
1 T52b/1 - Input - terminal 30 - for central locking
2 T52b/2 - Output for rear window wiper motor and windscreen and rear window washer pump
3 T52b/3 -
4 T52b/4 -
5 T52b/5 - Output for rear lid power latching motor
6 T52b/6 -
7 T52b/7 - Output for rear lid connection motor left
8 T52b/8 - Output for rear lid connection motor right
9 T52b/9 -
10 T52b/10 -
11 T52b/11 - Output for central locking motor in rear lid
12 T52b/12 - Output for terminal 15 voltage supply relay
13 T52b/13 -
14 T52b/14 -
15 T52b/15 - Output for switch and instrument lighting rheostat - terminal 58
16 T52b/16 - Output for sliding roof control unit (authorisation)
17 T52b/17 - Output for sliding roof control unit (activation)
18 T52b/18 -
19 T52b/19 -
20 T52b/20 -
21 T52b/21 - Output for heated front seat and rear seat control unit
22 T52b/22 - Output for heated rear window relay
23 T52b/23 -
24 T52b/24 - Output for hazard warning light system warning light
25 T52b/25 -
26 T52b/26 - Output for tank filler flap locking motor
27 T52b/27 -
28 T52b/28 - Output for X contact relief relay
29 T52b/29 - Output for voltage supply relay, terminal 50
30 T52b/30 - Output for switch and instrument lighting rheostat - terminal 31
31 T52b/31 -
32 T52b/32 -
33 T52b/33 - LIN bus - windscreen wiper motor driver's side, rain and light detector sensor
34 T52b/34 -
35 T52b/35 -
36 T52b/36 - LIN bus - anti-theft alarm system
37 T52b/37 - Output for deactivation warning light of interior monitoring and vehicle inclination
38 T52b/38 - Output for fuel pump control unit (for petrol engines)
- Output for additional heater fuel pump relay (for diesel engines)
39 T52b/39 -
40 T52b/40 - Output for headlight washer system relay
41 T52b/41 - Output for dual tone horn relay
42 T52b/42 - Input for interior light - terminal 30
43 T52b/43 - Output for interior light - terminal 30g
44 T52b/44 -
45 T52b/45 -
46 T52b/46 -
47 T52b/47 -
48 T52b/48 -
49 T52b/49 - Input - terminal 31
50 T52b/50 - Output for footwell illumination
51 T52b/51 - Output - terminal 58d
52 T52b/52 -
C - 52-pin connector, (brown) T52c:
1 T52c/1 -
2 T52c/2 -
3 T52c/3 - Output for tail light bulb, right
4 T52c/4 - Output for brake and tail light bulb, left
5 T52c/5 - Input - terminal 31
6 T52c/6 -
7 T52c/7 - Input of hazard warning lights button
8 T52c/8 -
9 T52c/9 -
10 T52c/10 - Output for Interior light (interior light, 31)
11 T52c/11 -
12 T52c/12 -
13 T52c/13 - Input of steering column electronics control unit - terminal 86s
14 T52c/14 - Input of steering column electronics control unit - terminal 50
15 T52c/15 - Convenience CAN bus, high
16 T52c/16 - Convenience CAN bus, low
17 T52c/17 - Input of brake light switch
18 T52c/18 -
19 T52c/19 -
20 T52c/20 -
21 T52c/21 -
22 T52c/22 -
23 T52c/23 -
24 T52c/24 -
25 T52c/25 - Output for fog light bulb, right
26 T52c/26 - Output for side light bulb, left
27 T52c/27 - Output for number plate light
28 T52c/28 - Output for reversing light bulb, right
29 T52c/29 -
30 T52c/30 - Input - terminal 31 (not valid for vehicles with automatic gearbox)
- Input of double clutch gearbox mechatronics (only on vehicles with automatic DSG gearbox - 02E)
31 T52c/31 - Input of steering column electronics control unit - terminal 15
32 T52c/32 - Input of alternator - terminal L
33 T52c/33 -
34 T52c/34 - Input for voltage supply relay, terminal 50
35 T52c/35 - Input of switch and instrument lighting rheostat - terminal 58s
36 T52c/36 -
37 T52c/37 -
38 T52c/38 -
39 T52c/39 -
40 T52c/40 -
41 T52c/41 - Input - aerial cable for 2-way radio remote control for central locking motor
42 T52c/42 - Input - terminal 30
43 T52c/43 -
44 T52c/44 -
45 T52c/45 -
46 T52c/46 - Output for main beam bulb, right
47 T52c/47 - Output for rear fog light bulb, left
48 T52c/48 - Output for left headlight screen adjustment magnet
49 T52c/49 - Output for right headlight screen adjustment magnet
50 T52c/50 - Output for turn signal bulb, front right
51 T52c/51 - Output for turn signal bulb, rear left
52 T52c/52 - Output for dipped beam bulb, right
- Output for gas discharge lamp, right
Wow, this looks quite a project!! Thanks both for the info, I will try this as soon as the weather gets better up here in Sweden, looks like I will have to do a lot of work in the floor.
BTW, any idea of all parts pricing?
