Meta System Alarm settings...
Hello guys,
I just bought new Skoda Octavia Facelift before a month. I have an installed Meta System HPA 3.5 alarm on it. When i arming the car the flashers of the car blinks once and the alarm is on. When i disarming my car - they blinks twice and after that alarm is off.
Sometimes i am wondering "Did i switched the alarm on? Hmm... Maybe not, just i have to check..." - If i hear a sound when i turn on/off the alarm i will feel much more comfortable. Can i switch the alarm sounds on by the remote or is there any other way to do this?
If anybody with the same alarm can help me, I will be very thankful!!!
Thanks in advance!
Regards
Edited by shaft
Nobody knows?
I can't contact Meta System, to ask them for solution...
Edited by shaft
Do you want to p!ss the neighbours off....
I am sure I can remember if I have locked/ set the alarm on my car....
I can't understand :)
Meta alarms is an after market product, so it wrong to assume that members of this forum will have knowledge of it. rudeness will not help. My wife's Fiat has a Meta alarm, dealer fitted, which has no audible confirmation. I wonder if you are assuming that the Meta will do it, because it is a feature of the OE Skoda alarm?
Almost all Meta alarms have the same options. Send me private msg with your mail address and I'll send you service manual for Fiat and for Skoda.
Guys,
Thank you so much! I have read the manual for the alarm, but there is nothing that can be reprogrammed without a computer i think :)
Regards
Programing mode:
-activate alarm
-turn ignition key to on
-press button A on the alarm remote controller 4x
-you will hear BEEP confirmation LED is blinking quickly
-Press button on LED panel 1x
-press button A on the alarm remote controller 1x
-Ignition off
Well done. Beer for me :)
Programing mode:
-activate alarm
-Ignition off
Hello guys,
Thanks in advance!
Regards
I have exactly same model of Meta alarm. Since it can be incorporated into can-bus of yor vehicle it is used with original Skoda remote! I remember when my friend installed it for me, he asked me if I want to have audible warning! He had some device by which he was able to code alarm! It can be easily changed by experienced person!
Programing mode:
-activate alarm
-Ignition off
You've got a beer!!! Many beers!!! It works just perfectly!!! I have a beep on/off sounds of the alarm now! This works perfect!!! Only with the remote control and the LED panel inside the car! No computer needed for this!!!
Thank you so much!
Regards
Edited by shaft
