Just fitted Jabba single mass flywheel and clutch kit.
Just fitted jabba single mass flywheel and clutch kit does anyone else get juddering when pulling away it's prob just me and it does that lol
I have the superpro dogbone bush fitted as well if that makes a dif?
But apart from that it feels alot nicer to drive with :-)
yep,and the clutch is a good bit heavier too i found,its not just you buddy
Ali stalled mine after fitting the Superpro bush... :p
You want to try my clutch! Nearly every time it ends up in a garage for tyres/mot or whatever, the mechanic driving it stalls it first, despite my warning. :D
tried your clutch too,my car did have a habit of breaking clutches :p
Which make fly and clutch did u get? And how much did it cost? Am thinking on buying the helix smf and clutch for mine!
i had a jabbasport/ sachs clutch and which replaced the monster spec stage 3+ clutch and flywheel imported from the states and capable of handling 600ft lbs of torque.......i broke it :rofl:
both were reasuringly expensive!!!!!!!!!
Edited by oilburninnut
my sachs clutch kit and smf from jabba was about £900
Edited by warwick hunt
my sachs clutch kit and smf from jabba was about £1600.
wow they have gone up a bit,think mine was 1100,the spec was about 1000 but it was over $2 to the pound when i bought it so was helped out a bit there
How much should it judder feels like it gona stall sometimes lol that normal then yer?
yep,just give it a few more revs when you set off,or for the fastest starts rev to 4k and drop the clutch in 2nd
my bad was thinking turbo price as well...
smf and clutch kit was £900 ish inc vat.
Ok cheera for that Gary I'm slowly catching you up think we are prob the 2 most modified SE's :p
I wouldn't be so sure.. We had a customer in recently who had a 2004 fabia who then bought a SE and had all his mods carried over and the 2004 reg put back to standard.
Mods included Turbo Dynamics Stage 2 Turbo, JabbaSport/Sachs SMF Clutch Kit, Pro-Alloy Intercooler, Snow Performance water injection etc etc. 230bhp 360ft/lb ish
Kev
Edited by Jabbasport
Oh ok maybe not then lol but ill will be coming down to you guys this month for another remap :)
Edited by chrisw_vrs
Everyone who drives my car stalls it! I just like to laugh at them! Mine has a Jabba SMF & Sachs clutch kit on it too!
Yep we mapped a pretty monster se the other day, i wont give away who or where from as they enjoy anonimityemoticon-0148-yes.gif
Edited by allytech
nope,yours is without a doubt the most modified se,as i put mine back to standard and sold it 12 months ago due to being made redundant :o
Got a problem with my clutch now it go into gear!
We have bleed it through, it's fine with engine off pedal feels fine But as soon as you put the engine on and pump the pedal it goes all soft again! Has anyone replaced any other bits when they fitted there's? Or has any ideas?
sounds similar to the problem i had with the spec clutch,turned out to be the springs had all disintigrated on the clutch plate,but you could try re fitting the linkage first as maybe it is missaligned
i got my clutch and flywheel fitted today.............but its making a hurendus loud rattle noise out of gear and not as loud in gear,. smells abit aswell. any hints?
noise is normal with smf and normal quieter with clutch pedal depressed.
hmmm, well its quite a loud rattle so i aint sure if its norm or not. it realy does sound **** at traffic lights tho rattleing away haha
