Strange noise when braking
MY 99 1.8T SLXi
Developed a noise when braking
Only evident just before coming to a stop.
Pretty sure it is not ABS kicking in
Can feel it more through the brake pedal, more than hear it
Feels like a few clicks through the pedal
Can not feel anything if you press brake pedal when stationary
Doesn't appear to do it when braking from higher speeds
Need to brake firmly just before coming to a stop to feel the, when weight transfer to front suspension
Garage can not find anything wrong, front wishbone bushes just done
Do not think that this problem was there prior to new bushes being fitted
ARB bushes done less than 6 months ago.
Front disks fairly rusty on inside surface, typical for my car
Any ideas
feeling though the pedal sounds like the ABS pump is working. Maybe your tyres are gripping the road a bit better since having the wishbones changed....
I agree with mbames it's more likely to be ABS pump you can feel. Just before you come to a stop is when it's easiest (requires little effort relatively) to lock a wheel.
There's an easy way to test -- pull the fuse for ABS (you'd need to look at the listing inside the fusebox, or in the handbook, or search the web to know which one), only takes 2 seconds and you can verify for sure :thumbup:
This is also a candidate, but more likely to be present at all speeds, even if quieter / less intrusive at higher speed.
Hope you mean rust up the middle vent of the disks, and not the surfaces which the pads press against, otherwise you have issues with sticky calipers. A light bit over over-night rust is ok, but should wear off after one or two light applications of the brakes. If it does not wear off, then you need to look at the brakes in more detail.
Edited by mbames
Thanks for the inputs :-
Will pull ABS fuse to test
Need to do disks and pads soon, although rusting on the inside braking surface of my disks
always develops on my car, short distance work, I replace the disks every couple of years due to this
Pads will hardly be worn, annual mileage only 5K
Piston is acting directly on the front disk surface, caliper slides are free pads are free
I really need pads that have a higher disk wear rate.
Any recommendations for this, no race pads that need higher brake temp to work.
Adoks
