Running with MAF off
As per title im runnin with the maf off apart from less mpg what other drawbacks are there and how long should i run it for before putting it back on.
why would you want to do that? plus the car will be dreadfully underpowered and slow!!!!
Normally do it just to check if the MAF is working or not, if you are getting rough running or a lumpy idle.
When the MAF is unplugged the ECU uses preset values, which is not ideal as it is basically guessing how much air is coming in, but if this means the engine runs smoother then it's time to find a replacement MAF and fit it.
I put a panel filter in earlier in the week and forgot to plug the MAF back in, got a CEL light come up so I suppose that's another side effect of running with the MAF unplugged.
Edited by chicken_eyebrow
you will have more probs and will get more codes due to over fueling......why did you un plug the maf? if the car ticks over better when the maf is un plugged doesnt meen your maf is gone as i had that prob and turn out to be a air leak...but could be your maf
Where was your air leak? How did you find it?
now ive unplugged it again, it runs ALOT faster with the MAF off. so new MAF time?
Yep, definitely new MAF time!
i had that prob with maf so i charged it and it happened again so i took it to awesome gti and the secound time it was not the maf it was the claw pipoe and the pipe that goes in bitween the inlet manifold as they were leaking ...but yours will probably be your maf..
Edited by vrsjaw
good to know anyway, they're £165 on ebay!!! Cant afford that, anywhere cheaper?
go to vw dealer 80gbp for a maf thats how much i paid .....a lot of people buy them cheap and you no wat cheap parts are like.......
would skoda dealers charge a arm and a leg.
80 is nothing buddy and you can change it your self.......
Depends what engine he has, there are loads of different mafs all with varying prices, and as long as the non gen part is same manufacurer eg bosch, its fineemoticon-0148-yes.gif
