Octavia II combi rear stop light bulb replacement
Hi,
Does someone know how to access the rear stop light bulb? It is positioned in the outer circle of the rear light house and the operation manual only descripes the center piece with the two bulbs of one is the flash light.
Regards,
K
Open the boot, remove the carpeted 'hatch' cover by the lights, and you should see the back of the light unit. Undo the clips (I can't remember exactly how, but its quite obvious), and change the bulb. Re-fit all it.
