VAGCOM obd port?
Where is this port in the car? I've just had a look but couldn't see it.
I would have used search but can't search anything whilst using an iPhone.
Cheers.
headlight switch, cubby hole underneath....
or atleast is on the ibiza :D
Yeh thats where mine is located
And pull cubby hole flap RIGHT down when it gets to a point of resistance. It should hang right down to expose the port. :)
Thanks.
I pulled the wee shelf down but didn't want to pull any further.
Yeah, I find it easier to pull right down and gently squeeze the two bits that it hinges on togther and just remove the whole thing. Easy to put back but it gets it out the way, especially when you want to drive whilst vagcom is plugged in - to log certain things, etc. :)
From what I can tell you can't break it. Give it a good firm pull.
Oh the days of having a dash....
