Diagnostic Code Advice
I originally posted this in the wrong forum:
Hi people,
Bit of a long post this one, sorry.
I could use some advice. I've just had a 2005 Octavia Elegance 1.9 TDi that I bought a couple of days ago scanned by a mate (engine running) and noticed the following (I've edited out the unimportant bits):
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 K HW: 028 101 223 7
Component: R4 1,9L EDC G000SG 7002
Revision: 12345678 Serial number: SKZ7Z0E3111347
Coding: 0000071
Shop #: WSC 73430 790 00000
1 Fault Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
P0671 - 000 - -
Freeze Frame:
RPM: 882 /min
Torque: 39.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101100
Temperature: 12.6∞C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenks‰ulenmodul 034 0070
Coding: 0000042
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 01D002007F2D8505485F861004CC
Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 B HW: 1Z0 035 161 B
Component: Radio FO3 012 0028
Revision: 00012000 Serial number: SKZ7Z3E0035030
Coding: 0000400
Shop #: WSC 25056 576 14179
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
The engine fault is obvious. I have a bad glow plug so that's OK. I can trouble shoot that with a multi-meter. It hasn't thrown up a MIL though which I'm not sure about. If it's bad it should throw up a light unless it's an old code and has not been cleared?
ABS breaks - Intermittent. Could that be down to cold weather logging a code?
00888 - Wiper Switch for Intermittent Operation (E22) - This is a common fault on Octy 2. Again cold weather or switch fault?
01135 - Interior Monitoring Sensors - Intermittent - where are the interior sensors on the Octy 2?
Radio - 01044 - Control Module Incorrectly Coded
000 - -
This one has me puzzled. No errors in Address 19 - Can Gateway. Stream Radio and CD changer all work fine. Rear parking sensors show up OK as does Climatronic. Sound is good. AFAIK I have no special active speakers etc (although seller said 'premium sound system' in ad). No telephone preparation. AM and FM reception is good enough and system menu says 'Antenna on'. Any ideas what this fault is all about.
Current coding is 0000400. What should the bog standard coding for a Stream with no maxidot and standard steering wheel be? As far as I see there is no basic coding for the Stream.
Also I didn't get the security code for the radio. Can a dealer generate the code from the scanned info?
Any help will be gratefully received. Everything else seems pretty good with no error codes showing.
Thanks in advance,
Mark
Coding: 0000071
1 Fault Found:
P0671 - 000 - -
Freeze Frame:
RPM: 882 /min
Torque: 39.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101100
Temperature: 12.6∞C
Bin. Bits: 10110000
Not all faults cause the MIL to light. Only emissions related faults must cause the MIL to light. The fault is not showing an intermittent status so the ECU at the time of the scan was still seeing the glow plug problem. Troubleshoot that and when it is corrected, clear the code.
An intermittent fault by definition is one which has been set but was not present at the time of the diagnostic scan. Clear the code and see if it returns.
Again, the fault is intermittent - if you have not noticed any problems here, I would clear the code and see if it returns.
- Sorry, I can't help with this one. I don't know the Octy 2. We don't see them on this side of the pond.
000 - -.
Did you make any changes to the radio? I have seen this error come up on cars and never cause a problem with the operation of the radio. Not sure it is one to worry about since the radio is working fine. As to the Radio code, the dealer can use their scan tool and their to the factory to set the radio code but I don't see a reason for you to spend your money to have them do this when the radio is working fine.
0888 is the switch on top of the wiper stalk that sets the sensitivity of the auto wipers.
It's worth trying some switch cleaner in there, but otherwise it's a new stalk if it comes back.
Interior sensors are the alarm sensors and they are located in the area in front of the sunglasses hold/lights in the front middle roof area.
There was a bad batch of these and IIRC the solution was replacement.
The T30 voltage low, sounds like the car had a weak/ flat battery and that caused it.
As Bruce says, I'd clear the lot, take the car for a run for a week, then rescan it and see what has come back.
Thanks for the info.
I've heard of a lot of complaining that the sensitivity switch seems to do nothing at all or is erratic. Maybe down to misunderstanding how the sensor behaves in variable driving conditions or maybe the switches are prone to intermittent failure.
I'll also check the fuse on the ABS. Could be a wrongly rated fuse is in there and getting hot. That would definitely pull the volts down.
Thanks again.
