faulty indicators
i am having a problem with my indicators which is quite strange. if i am driving in a straight line my indicators will only flash twice. but if i am turning they stay on . can anyone shed any light on my problem???? thanks
Sounds like a faulty indicator relay, its integrated into the hazard light switch so if you replace that then your problem should be sorted.
That or the self-cancelling's got bent. Can you get more flashes if you physically hold the switch on?
yes i get more flashes if i hold the indicator down..
also some times it seems to work ok. strange!!!!
That sounds like a problem with the self-cancelling mechanism, which is purely mechanical. There's no guaranteed way of fixing this.
