Octavia VRS FL LED Lights
Hey
Does anyone know if the VAG COM system will change the way the LEDs on the front of a facelifted Octavia VRS lights up so that it doesn't get dimmer when the main Xeons are switched on??
I may beable to borrow someone's cable and software to make a few changes but if that cannot be done then I won't bother.
They get dimmer for a reason ,they are DRL`s _ Daytime Running Lights , so will be less bright at night . you would dazzle people if they were not dimmed :thumbup:
D'oh. I was hoping that would not be the case. I thought you could at least change them as the Xeons would still be brighter.
