Nokia ck7w
Hi am fitting a nokia ck7w car kit and wonder if anyone can help me with this.
Where should I connect the blue ignition feed to. car is an 08 vrs.
thanks
Ifor
thanks
Ifor
You can find a switched +ve feed on the fuse box - behind the o/s end dash panel. The fuse box is secured by 2 torx head screws, one at top & bottom.
You can identify a wire (can't remember colour) that is live when ign switched on and with engine running, but not when key off. I cut the insulation off hte wire a bit further back from the fuse box, then twisted a wire on and soldered/insulated the connection.
It's easier to do this by dropping the o/s underdash panel:
Remove the coloured trim strips carefully - they just unclip - this will reveal the torx head screws that hold the top.
Remove the light switch - turn it off, push in anticlockwise and then it simmply pulls out.
There is also a screw lower down.
You will probably need to remove the OBD port as the wiring is very short - this unclips; insert a small screwdriver in the space above and blow port skt to release the clips.
H.T.H
John.
Just remembered - I should mention that it is not possible to find a feed that stays on with the "key in" position - unless you use a CAN bus adaptor.
J.T
Edited by JayTee
John,
Many thanks will give it a go.
Ifor Davies
