Front top mounts
I've done a search and found some interesting threads but still not quite sure!. I want to fit coilovers to my TDI estate and will replace the top mounts. Which ones should I fit, standard or sport ones and I assume they don't come with the bearing so will need to buy these too?
Also what size is the nut on top of the damper shaft and will I need a stepped ring spanner to undo this?
strut top part number
6Q0 412 331 B
tbh if it aint broken dont fix it :)
about £15 iirc
Edited by jasc1988
