Felicia starting problem
I have a Felicia 1.3 LXI on an S plate (1998) and I have just changed the radiator fan switch. The car was running but the fan did not cut in, so I was pulling the fuses to see if any had blown, as I did this the engine stopped and will not restart. Everytthing else works fine, the engine will turn over fine but it seems as if there is an immobiliser on it and I don't know how to reset it. Can anyone help please.
Has it got a third-party immobiliser? As far as I know standard stuff shouldn't behave like that.
did you pull the fuses whilst the ignition was switched on??
Its ok all sorted now, the fuses looked fine but one of them was dodgy. Thanks for the replies.
