Fabia Estate - when rear washer is used water drips from rear wheel arch
Hi,
I know this topic has been discussed many times.
When i operate my rear washer, water drips down by the nearside back door at the bottom of the wheel arch.
My question is, does the tubing to the rear washer run in this area, is it external or internal, and how do i get to it ?
Thanks in advance guys.
The pipe to the rear washer is located behind the passenger side rear pannel which covers the arch. You need to remove the plastic trim surrounding the inner pannel and you will see the washer pipe. Just clip it back together and refit the pannel and trim.
If and when you carry-out advice as rookwise quite rightly has told you, would it be possible to take a photo of offending pipe in its correct position, and post on this site for all to see please. ??
