part number help needed please?
Hi guys,
I need to change the front bushes on my wifes Fabia Elegance 1.9 tdi and i need the part numbers as i can get the bushes from my local SEAT dealer with a discount.
I need the part numbers for the anti-roll bar bushes, front wishbone bushes, is it worth changing them for cupra one's?? and i also need the anti-roll bar drop links. I am going to change the rear wishbone bushes with cupra ones but i've got the part numbers for them already.
Thanks in advance,
Tim
By front wishbone bushes do you mean the track rod end ones? They are (left) 6Q0 423 811 and (right) 6Q0 423 812
The front ARB bushes appear to be part of the connecting link between the end of the ARB and the suspension strut. The part number for this link is 6Q0 411 315 (same both sides)
If you are referring to the bush at the end of the wishbones that bolts in to the wishbone using 3 bolts and goes into the bottom of the hub, this is (left) 6Q0 407 365 and (right) 6Q0 407 366
Hope this helps a bit.
Hi devonutopia,
By wishbone bush i mean the forward bush that is on the inner part of the wishbone, and by anti-roll bar bush i meant the bushes actually hold the roll bar to the car.
Thanks for the other parts though.
Can anyone help, I just need the anti-roll bar bush part number ???
