Scout ground clearance
Has anyone considered and/or tried raising the Scout to get a bit more than its 180mm of ground clearance? I look at the Volvo XC70 with its 210mm of clearance, and think, yeah, I'd like some of that. Then I look at the price for what is essentially a blinged up Ford (actually, it's now Chinese...) and think, yikes!!
Koni or Ohlins must be able to do a replacement.
Try MAD suspention systems ,I have assister coil springs on the rear of my Scout and it's raised it about 10mm at the rear .
[/quot
Edited by patrol man
Have you driven a XC70? I rides like a boat, all wobbly because of that height.
I haven't. However I'm not one to throw the car around too much anyway, otherwise I would be looking at a VRS ;)
Good find! they even have air suspension systems :o :o may be overkill but still :rofl:
Will have to fire them an email and see what they think about raising a scout. Cheers
Just remember that if you lift it too high, you'll increase the wear on the pros shafts etc... because of the increased angle - although you might be able to get replacement items designed for greater ride heights.
