Front Lower Chrome Grill
Photo of latest addon
Before
After
Edited by drbig
oooo i quite like the look of that :yes:
So.....
Where from?
How much?
How east to fit?
:rofl:
Simon
So.....
Where from?
How much?
How east to fit?
:rofl:
Simon
Cobra Technology & Lifestyle
:blush: too much
Very simple to fit if you can operate a screwdriver then you should have no problems
I like the look of the chrome grill. When our Yeti finally arrives (3 weeks?) I won't be modifying as it's a lease :(
Finally seen one in Newcastle area, in my rear view mirror driving behind me on a large roundabout, possibly grey or Aqua blue? They are elusive - but out there!
Before
After
I've got this for mine along with the Stainless Steel Side Steps (being fitted by the dealer). It looks nice! emoticon-0148-yes.gif
Has anyone gone for the exhaust trims ?
I ordered them for my 1.2, but the dealer advised the exhaust needed cutting to fit, so bottled out.
On one of the gold forums someone has fitted these to their Mk6 and ignored the fitting advice - they just slid straight on.
The exhaust trims are fitted as standard on the elegance model
The dealer fitted the chrome trims to my 1.2 Elegance. The Skoda accessory instruction that came with the trims requires cutting off the end-angle section (approx 50mm) from the actual exhaust pipes first so you are left with a straight end to the exhaust pipe. The trim`s are then fitted to the pipe section using some flat spring clips that fit between the pipe and chrome trims so are not visible. I think the pipe needs to be cut so the trims do not stick out too much at the rear and also the spring clips supplied would not hold the trim at the bottom of the pipe where there would be no metal due to the original angle on the exhaust. Hope this makes sense
Regards, Del
Better than the wood trim but still a no from me. I just can't see the point of turning a Yeti into an X Type
Just my opinion and it's a free World.
This is how it looks. In my opinion, it is elegant, not race oriented. Also note that they make the exhaust slightly shorter.
I did the mod me self (used an iron saw and a Dremel).
Cutting is obligatory. No way to install without cutting the ends.
Before
After
Blah! Have to say - Bling 'orrible? Sorry.
Yeti, IMHO, is not a 'bling' type vehicle - who will be the first to do a colour coded radiator grille?
I think the radiator grills look good as they are :p
  • 4 months later...
Just wondering if anyone has seen chrome inserts for the upper grill? I don't want a totally chrome look, but just possibly 10 or so pieces of chrome strip to go between the dip on each of the vertical plastic bits (a little like the Tiguans)
It wont even show me the photos says they are unavailable ??
It's as easy as going to Halfords and buying 3 meters of this Chrome trim and sticking it to the grill. Job done.
Thanks! I will definitely have a look at this, I also want those black wheel arches, might speak to the dealers to see what they can do.
Dont like it, looks like a dogs dinner, too bling. Not for me this one nope nope nope emoticon-0145-shake.gif
Take it you don't like it then
Looking at the state of mine at the moment, it wouldn't matter how much "bling" you put on it, it still wouldn't look shiny!! :giggle:
Naaa !...far too chip shop for me !
I keep looking at both pictures and I can't spot the difference. :giggle:
I keep looking at both pictures and I can't spot the difference. emoticon-0136-giggle.gif
