octavia vrs boost problem
hi im new i have a 53 reg octavia vrs with a slight boost hesitation between 2nd and 3rd gear,i have changed the airflow meter,boost pressure sensor,fuel filter.fuel presure reg valve,coolant temp sensor and im lost what to do now it only happens between 2nd and 3rd gear when you drive normal its fine if you put your foot down there a slight hesitation then its powers round ive also cleaned the throttle body and new plugs and coils fitted and help please???
:) Hello mate, have you Vag com'd it yet? Welcome btw! :thumbup:
hi no not yet i will be doing next week i got told that coz i unplugged the throttle body to clean it i might of messed the settings up and it will need re setting??
no they dont need to be reset but it is good practice to do so but not essential
is the car mapped ??? could be a mapping issue if it is
really need to do some logs on vagcom
