columbus voice control
Hello
I ran a new 4 core cable between the Bluetooth unit and the head unit. I then made the following changes to the wiring:
Pin 7 (White wire from Green connector on HU) was connected to the wire from pin 11 on the BT unit.
Pin 1 (Brown wire from Green connector on HU) was connected to the wire from pin 12 on the BT unit.
Pin 9 (Green wire from Green connector on HU) was connected to pin 11 on the BT unit.
Pin 4 (Black wire from Green connector on HU) was connected to pin 12 on the BT unit.
Hope this makes some sense.
Liam.
Ok think I get you just to confirm. Have you run the Mic to the green connector on HU pins 1 & 7. Then out of HU 4 & 9 mic +,- out to the BT unit pins 11 and 12?
I'm lost on why my BT is working with the mic connect to 6 & 12 on the green connector there are no other wires on this currently. Then the main BT cable runs form the HU to the BT unit.
That's right :thumbup:
Cheers Liam will have a little play about with it.
If I push the voice command button this activates its just the women cant hear me, does this mean I already have voice command activated and I dont need to turn it on via VCDS?
.........i dont have bluetooth instaled on the columbus , but when i press the mic button (i) a lady talks to me ,can i just connect a eg. pc mic to 1 & 7 to see if it works?
You can try anything you like....
Just be aware that you may need to try with the (whatever type/make of) mic connected the otherway around.
