Omex shift light pro
Hi guys I've just bought an omex shift light pro I don't seem to manage to wire it to the car. I can't find were to solder or connect the blue wire for the tacho signal.Can anyone help please?
anyone?? :((
I don't know for sure Daemoncrx, but i think there's a possibility the tacho output pin on the ECU does end up getting routed to the instrument cluster, don't quote me on that though.
You'll need a pin out diagram for the dashpod connector(s). I can't help with that, but there is a pin out diagram for all of the bosch MED ecu's on the web -- which one have you got? Or which engine are you running and can make an educated guess from that.
For older cars those kits are a doddle to fit but i don't envy you fitting that on a modern canbus car :'(
