Fault Codes - Help Please
hi guys,
got the following fault codes showing on my car at the moment, can anyone help with them? what the issue is? and what needs doing?
sorry if anything is really stupid or straight forward. i'm not that clued up on cars so please excuse me if anything i write is stupid.
thank you all in advance
carl
codes are -
p1200
p0411
p1136
& it also says -
wastegate bypass valve
mechanical malfunction
secondary air injection
Check all the pipe work leading to the to the manifold and to the turbo intake pipe (tip). Had similair codes come up on mine and the breather pipe had a massive split in it under the manifold by the time i traced it. Does the car hunt at idle? If it does this would suggest some sort of air leak and it's trying to compensate
Guest westallc
have you still got the secondary system on the car and the n249 system????
if you have then the secondary air pump might be fecked normally the rivets have come off easy fix
and n249 will normally be a leak in the pipework or a fecked valve
p.s the search button does work by the way lol
Edited by westallc
