MAF reading high or low
Had Vag-com on my car to see if there were any engine faults on it and it came out clear :thumbup: , then did MAF test and got a max reading of 157g/s can some1 tell me if this is high or low :confused:
Thanks KEL,
Is that 0.157g/s or 1.57 etc.
Normally at idle it should read between 2.5 - 4.5ish AIR
In my VRS (Revo 4 bar) with N75J and HB4 ...i have up to 167-170g/sec in the Vag-Com.
157 is OK (you have std Revo setting in boost??)
Ya it's just std Revo wit N75J and it runs at 1.1bar norm, max 1.3bar @ 3,500 rpm and after 5k rpm it drops to .8 bar it that the norm?
Any1 no wot a std MAF reads!
that figure is there or there abouts yes..
LCR and other 210/225 motors will put out 190g/s, chipped Ibiza/Leons 160g/s approx.
Here is my Block 003 data for Air Mass & Ignition timing.
(last April data).
Mods at that time
Revo HB4 timing 6
N75J
Custom FMIC
Denso IK22
Dahlback DV
Samco TIP
Extra custom grounds
Neusouth intake manifold gasket
All other stock
I hit 177 g/sec at 6300rpm.
