Petrol VRS radiator fans
Hi,
I've noticed over the last week that when my engine fan is cutting in it is a bit noisy and doesn't seem to be totally balanced, so I had a quick look today and noticed that only the larger of the 2 fans is cutting in and the noise/vibration is occuring when it is running flat out.
Should both fans cut in or is the smaller one only in place in case the larger one fails?
I should mention that there is not a temperature problem with the engine.
Thanks inadvance
Paul
Probably air con, it will use both fans if needed.......... been bloody hot dont forget.
Thanks for the reply, i've got her booked in for a service next week so I'll mention it to them.
Paul
